Skyliner123
So this is my first winter with a Campervan and at the weekend I thought my fridge was broken as the compressor wouldn’t start even though the lights were on. It is a Sanjo SVR50 (Waeco/ Dometic CRX50 copy). Anyway to cut a long story short I didn’t give any thought to the fact that the already low temperature in the van meant that the fridge temperature even turned off was down to around 4 degrees C. The manual of the SVR50 states a temperature of between 5 and 12 degrees c which I thought sounded high (the CRX50 manual states 3 to 12 degrees c)? Also don’t even look at what ambient temperature range both manuals suggest the fridge works in! I managed to get it to kick in on the highest setting by leaving the fridge door open for a bit with the diesel heater running so am assuming/ hoping there is no actual fault.
During the Summer we only used to have it running on around the 3 out of 5 temp setting but going by the specification that would make it around 7 or 8 degrees c which is far too warm and we would surely have noticed so am I missing something here?
Any help/ advice appreciated.
