I could do with a bit of advice if anyone has the time, please?
Having had our Kombi for 7months now (2016, 150, Highline @ 47k miles) we have had an awful week with the glow plug lamp flashing up and showing faults. The engine was mis-firing and wouldn't function well over 2000rpm, resulting in immediate 'limp mode' activation. Our local garage took the van in and diagnosed a camshaft sensor fault, which they replaced and then went out to drive the van and on starting it up again the following day, the crankshaft sensor also failed. This too, was replaced, and the van driven to establish any further issues. It seemed ok on the drive home...... until the following day.
The glow plug lamp is flashing again, and I am waiting for a friend to come over to get the codes read to see what it could be, this time. With little to no experience of this kind of issue, i need to ask the forum if this could all be a result of an issue with a recently replaced cambelt? Could lack of tension produce these sensor faults and if so, am I in a good position to ask for this to be sorted by the garage and the sensors parts and labour costs (over £300) refunded as a result from installation error?
This is all out of the blue, but following a recent cambelt/pump replacement. Am i getting hung up on something that probably could happen to anyone... Any thoughts welcome. It's booked in to the local garage on Friday, but I'd like to see if anyone out there has had similar issues? Thanks.
