Can I Activate Lane Assist with VCDS?
z1ts
Good day ye who are cleverer than I...
I have a T6.1 (MY23) as per my sig below. I have ACC. I would like to activate if possible Lane Assist.
Doable?
Do I need more hardware to get this to function or is it a few button clicks on my trusty laptop?
Thanks in advance!
Tagging some who I've picked up are good at this sort of things: @mmi @Robert @BognorMotors @Dav-Tec
Cheers!
(I have searched the Forum before you ask!)
Yes, sigh....!
I think I need a new front facing camera, new windscreen, new control module(s) and a plethora of other bits by the look!
Oh well - was worth a punt to fiddle about in VCDS to see if I could get it working.
I think (although I'm not certain) that if you have the A5 camera (which I don't) then this coding would work:-
Code:
Coding procedure
Module A5 → Long Coding:
Byte 00, bit 0 (Lane Departure Warning HCA) → installed
Module A5 → Adaptation:
HCA_On_State → Menu
HCA Warning Intersity → Menu
BAP_Personalisierung → disabled
Intervention moment → late (menu)
Personalization lane departure warning at a terminal 15 → Last setting
Module 44 → Security Access → 19249
Module 44 → Long Coding:
Byte 00 → bit 4 (Lane Assist) → installed
Module: 17 → Long Coding:
Byte 04 → bit 6 (Lane Assist) → installed
Byte 11 → bit 1 (Lane Assist information via BAP) → active
Module 5F → Adaptation:
Car Function List BAP Gen2 → LDW HCA 0x19 → activated
Car Function List BAP Gen2 → LDW HCA 0x19 msg bus → databus extended
Car Function Adapts Gen2 → Menu Display Lane Departure Warnign → activated
Car Function Adapts Gen2 → Menu Display Lane Departure Warnign over threshold high → activated
Press and hold volume knob for 10 seconds to reboot the system. Enable Lane Assist feature. Take the car for a test drive.
I got that from this video's description here:-
