Hi all. I have a 2019 LWB 4motion diesel T6 "Transporter" with AT tyres and a Dove Campers campervan (poptop) conversion. When ordered, I asked for the "HD suspension" option but I have no way of knowing if that's what I got. Dealers are unable/unwilling to give me the full specification.
The reason for the issue: I want to increase the ground clearance, have been looking at Seikel and Bilstein options for 30mm lift kits available in Western Australia -BUT one tech said "If it's HD suspension then it's already been raised" and that I might not get any more height out of the aftermarket kits.
With the odd weight distribution of a camper, body height/clearance specs are invalid, so what I want to do is get an idea of height. If anyone has a T6 camper AND has had a lift kit fitted, can you tell me - what's the vertical distance between the centre of your wheels and the body wheel arch on the outside, front and rear? (This takes tyre type out of the equation).
Mine is - Front 460mm, rear 420mm.
Standard T6 vans I have must checked -
Multivans (3) Front 445-460mm, rear 455-450;
Transporters (2) Front 465-475, rear 480-493.
So - is mine raised, and just very heavy (2600kg), or is the height standard? Any measurements / suggestions appreciated. Thanks, TTKT.
