Found a couple of threads on this but no real answer.
Caravelle - 2016.
I have THQ V1’s fitted and noticed the light bulb out warning popping straight up.
My Drivers side has the dipped beam out.
My Passengers side has the high beam out.
So far tried.
Removed THQ lights put back on original lights - still exactly the same issue.
Bulbs swapped back to forth. Feel if the original headlamps are doing exactly the same as the THQ lights, then not the light unit.
If i probe - the dipped beam has 0.87v with dipped beam off and drops to 0.77v. Working side is 12.4v when on.
I note the fuses - behind the bottle holder on Caravelle - doesn't actually have dedicated fuses to headlights - but another thread suggests looking at C3,C5,C12 & C41 - called onboard supply unit. Then have checked all the fuses here.
Changed out the light switch.
Yet to change - stalk & or ‘headlamp level switch’ next to headlight switch.
I even tried as someone else mention disconnecting the battery to clear the ‘Canbus’ for errors for 30minutes.
Any suggestions??
Caravelle - 2016.
So far tried.
Any suggestions??
