2016, no warranty, got breakdown but they are useless!Immobiliser?
Sorry, can't help any further myself.
How old is it? Do you have a warranty or breakdown cover?
Battery tested it’s ok."Battery seems ok" doesn't really say anything!
No dash lights.So youve got dash lights etc but it won't turn over ? Starter motor maybe ? Or like manfrotto suggests something like inhibitor switch cuz its not in park (if it auto of course)
no nothing like that ! After breakdown gear selector wouldn’t move had to manually reset and move to N to move the van to a safe place!not something like gear selector not in park, brake pedal depressed etc?
And the results of the testing? You need to post more information for people to try to help.
Not all of us are mind readers.
Any ideas where I can get hold of a wiring diagram?Started ok reversed to get out of drive and stopped in the middle of the pavement, no error message or anything. Now Ignition is dead no response when key is in and turned on. Radio works, battery seems ok. Ignition relay fuse is ok. Any ideas. Can anyone help please.
Thanks DaveD. If there is corrosion will the remote and radio still work?I'd be checking the earth lead from the battery to the body. Dodgy earth leads can cause all sorts of issues and your van is of an age where a bit of corrosion might have set in.
Try your battery tester using the positive on the battery and a solid earth point on the engine.
Possibly.Thanks DaveD. If there is corrosion will the remote and radio still work?
Thank your your time.Possibly.
On the negative battery terminal you have the thick earth strap which earths the body and engine, but you have, (or should I say, I have) several other earth leads.
I've no idea what they do but if they earth the central locking and radio via a control unit, it is possible that a poor connection on the main earth strap would prevent the ignition / starter from working while other earth cables allowed the radio and central locking to work.
I don't see what you've got to lose by trying it, I could have tried it quicker than it took me to type that lot.
How are you getting on?Thank your your time.
