Carista error codes
JasonW
VCDS User
T6 Legend
I can't seem to get these 3 error codes to reset or clear...
I'm thinking the two gateway errors are related to the aftermarket Kenwood 9190 thats fitted...
But I'm not sure about the instrument cluster error... everything seems to be running OK, so maybe nothing to worry about.?
Any advice appreciated
01300 (carista) J401 - CDrom/Navi CAN GW
03158 (carista) J794 - CDrom/info elec1 CAN GW
Boths faults logged after OEM radio/navi removed and 3rd party aftermarket radio fitted.
looks like the first one my be due to the Cluster missing messages from the Radio/navi too?
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5J0 920 911 M HW: 5J0 920 911 M
Component: KOMBI H02 0408
Serial number: 00000020120521
Coding: 410A00
Shop #: WSC 33361 790 00099
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_SK25.rod
VCID: 3261028865D1A08E527-8067
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 12
Mileage: 56 km
Date: 2000.14.31
Time: 17:12:49
so far its looking like a case of just ignore them.
or try removingf the old radio from the insralled list in the gateway. (but carista wont do that)
As above... looks like the CAN Gateway is still looking for "old" infotainment unit - so removing the old "5F-VW Infotainment" from Gateway setup and adding/configuring the new.
Thanks for the replies.... I don't have the know how or confidence to start tinkering with trying to edit these out, so I will leave them for now, especially if its nothing to worry about...
Second and final question is regarding the smart key buttons option below... Does anyone know what it's for...?
im not sure thats used for the T6,
smart key is a "keyless-entry" type radio key not used on a T6.
