VCDS scan of my T6, any ideas what the faults may be?
HoopDub
I fix stuff
I've just got done coding the tailgate conversion. performed an auto scan and a few faults popped up that I need a fresh set of eyes to go over. Central Elect and Instruments. I cant see any symptoms with regards to the door modules can errors, everything seems to work as it should. Same goes for the instruments, software issue??
here's the scan. any help appreciated.
Have just noticed something, when you unlock the van and open the sliding door only, the central locking auto relocks after a few seconds, so it isnt recognising the sliding door being open. Pretty sure it was before i sausage fingered the coding.
It's on the left/nearside/passenger side. But i didn't know what perspective vcds used i.e right side looking at the front of the van or from the drivers seat. It's also an option in the can gateway installation list.
The link that I posted is for a T6 California which has a sliding door on the right hand side. It's from the drivers seat.
I'm not too sure but I think 0D under 19 in the CAN gateway list is for an electric sliding door. Maybe someone with more knowledge than myself can help.
Just had a search on ross-tech and Left/Right is taken from a sitting occupant facing forward.
Did you scan the van before any modifications?
I thought i did, but i cant find it, must not have saved. i do have one from last year, the media unit has been changed since and had some coding done to make it work, but the unit died. I've fitted an alpine HU since so any media info may be out dated or NA
Reactions: mmi
Check the folder called logs within the VCDS install directory you should find all your scans there
Just checked and i clearly didnt do a before scan, school boy error :-(
I did find a newer scan before id fiddled with the tailgate coding that may help
Reactions: mmi
ALL the scans ever made (even not explicitly saved) are stored in Scans subfolder = C:\Ross-Tech\VCDS\Scans or if Beta-version was used at some point then the scans are in folder C:\Ross-Tech\VCDS-Beta\Scans
Looks like i didn't do a before scan o_O
I changed the sliding door from right to left now and it now recognises the door opening and closing, so another step in the right direction.
Reactions: mmi
The door controllers (subsystem 1 & 2) are lost - how did that happen? Does central locking work, electric windows, mirror adjustment?
Also multi-function steering wheel controller (subsystem 3) has disappeared? Do the buttons work?
Before modification - Friday,17,May,2024,18:55:29​
Code:
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 037180296
   Coding: E0A4303A0A212031002809742C2B8C550F00708F60464D70330400220840
   Shop #: WSC 02762 534 156453
   VCID: 2B030BC5E300CAD2D21-807E
   Subsystem 1 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU007021880382056
   Coding: 1400B1
   Subsystem 2 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU005021880361125
   Coding: 0400A1
   Subsystem 3 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000826340058201
   Coding: A4FFFF
No fault code found.
After the modification - Wednesday,18,September,2024,10:19:03​
Code:
   Coding: E0A439380A212012002809742C2B8CD40F00708F60464D70330400220800
   VCID: 2B030BC5E300CAD2DA1-807E
4 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:24
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:24
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:20
04194 - Vehicle Status with Under-Voltage
            002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:20
Code:
   Coding: 1400B1
   Coding: 0400A1
   Coding: A4FFFF
Code:
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:24
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:24
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:20
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 250781 km
                    Time Indication: 0
                    Date: 2019.02.09.
                    Time: 15:51:20
No idea how they would be missing.
The van did not come with a MFSW i retro fitted that, ran the new wires to the bcm, coded it and it works.
The central locking works. I havent tried the mirrors recently but im assuming they still work.
Can the sub systems be reinstated?
ok so I just went through the scan logs and found one I did a few days after I got the van.
I notice that the BCM coding is obviously different. Also 19 Can Gateway has different Coding. Shop# and VCID are different to what they are now.
Reactions: mmi
Update... I've managed to sort out all the faults apart from one. The one that remains isn't a fault so much as an indication that i no longer have an original headunit/media unit.
The loss of comms with the door modules was due to a bent pin 17 on the bcm.
The undervoltage fault i managed to clear by resetting the adaptation values for energy management.
