If there are no other engine faults present - then yes.
Along fault codes there would beis more detailed data - which Carista strips off, unfortunately.
E.g. below"MIL ON" = here the yellow submarine light
Code:
15918 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [236] - Electrical Fault
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 35315 km
Date: 2031.01.29
Time: 16:56:32
Engine speed: 927.75 /min
Normed load value: 35.3 %
Vehicle speed: 0 km/h
Coolant temperature: 18 °C
Intake air temperature: 18 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.742 V
Unlearning counter according OBD: 40
Preheat time: 2.5 s
Glow status: Post-heat
Extern.temp.sens.1 bank 1: raw value: 19.5 °C
https://forums.ross-tech.com/index.php?threads/24545/
