Big central MPH, teardrop wipe, and that cherry on the cake, needle sweep, make a Carista worth buying in my opinion, not to mention everything else these things can do.
Heated mirrors to turn on when you select rear heated screen.Brilliant gents.....many thanks! What do you think are the best mods....I'm thinking big speedo....needle sweep.....autolocking on/off.....turn off the auto rear windscreen wiper when reverse selected. I can't enable rear speaker fade can I? Any other thoughts gents?
I’ve got mine switched off, don’t like the fact it automatically comes on when you select reverse when your front wipers are on, just messes with me ocdWhy would you want the rear windscreen wiper not to work when you are in reverse?
In freezing temperatures...Why would you want the rear windscreen wiper not to work when you are in reverse?
It's just something else to go bang when the wiper blade is frozen to the back window and I've forgotten to check it's free before starting up. And also what @Northern Monkey said.Why would you want the rear windscreen wiper not to work when you are in reverse?
Does it work for you?...gallons to fill up (though I'm not sure what the point of that is?)...
Funny you should say that @mmi.....no it doesn't! I think I'll remove it because it just shows a broken line. I don't know if the heated mirrors with rear screen works yet....I guess I'll find out this weekend. Does this mean, the mirrors ONLY come on when the HRW is switched on? Do they have to be left in the ON position so that in effect, they only actually switch on when the HRW switches on?
No, you don’t need to leave the mirror switch in the heated position, and yes you can still operate them separately with the door switchFunny you should say that @mmi.....no it doesn't! I think I'll remove it because it just shows a broken line. I don't know if the heated mirrors with rear screen works yet....I guess I'll find out this weekend. Does this mean, the mirrors ONLY come on when the HRW is switched on? Do they have to be left in the ON position so that in effect, they only actually switch on when the HRW switches on?
That was what I assumed. although you know what they say about assumptions.No, you don’t need to leave the mirror switch in the heated position, and yes you can still operate them separately with the door switch
Set the instruments to Australia. Then turnoff the alt speed in mfd then enable digital speed in mfd data.On my dash the digital speedo shows as kmph instead of mph.
I have a carista but can't find how to change this to mph. Any ideas?
Also i see reference to making the readout larger. How do i do this as i can't see that as an option
