Yes mate, fitted a few since then you just want a ignition supply if it's a T5 you can pick it up under the passenger seat or I pick it up from behind the fuse box if it's a T6 or behind heater controls don't cut any cables just use a splice clip, cable from B2 from power unit B2 don't bother with B1 with a inline 50amp fuse as close to the leisure Battery as possible, then from your van battery to dc to dc charger to your leisure battery 50 amp fuse as close to vehicle battery As possible, hope that makes sense
Evening camperman1 and anyone else who is able to help on this topic.
I am doing my first conversion and trying to do as much myself as possible, I thought I was nailing it with the cbe pc200 solving all my electrical issues but it seems not since I am working on a T6.
Can someone confirm back what has been said just so I am clear and answer a question or two?
I am planning to wire the cbe unit as the instructions but leave out the van battery to cbe connection. This entails connecting the leisure battery to the unit with 50am inline fuse and the mains hook up.
I will then need to take a wire to an ignition supply complete with a 3 amp inline fuse but I am unsure about where to plug this into the cbe unit?
I will then take a cable from the van battery via a 50amp fuse and dc to dc charger directly to the leisure battery.
Does this sound right?
If so, is the only downside the additional cost of the dc charger and the lack of a power level indicator on the cbe display for the van battery?
Lastly, if I leave out the wire to the ignition does this just mean I will always be using the leisure battery unless on hookup?
Sorry everyone, but thanks massively for all the comments I’ve read to help me get this far.
