Thanks for the clarification guys.
H4 or H7 headlights?
Just changed all the front bulbs on mine from Travelinlite very happy with the price and service
I bought some of these LED bulbs for my DRL's, they are very good, bright as you like, and a good match for the other LED lights I have on the van.
2x P21W CANBUS White Car Turn Signal Rear Light PHILIPS LEDs 1156 BA15S 382 80W | eBay
Check out PowerBulbs website.... I get all my bulbs from them.... easy/clear website and quick delivery!Hi there I would like to change my DRL's on 2016 VW T6 would these fit also its says turn signal rear tail light does this matter
They are suitable as a replacement for a 21W bayonet fit bulb, but they are bright white, would work in an indicator where there is an amber lens on it, or brake light with a red lens. I wouldn't use them as a tail light, too bright and would look like your brake lights were on all the time.Hi there I would like to change my DRL's on 2016 VW T6 would these fit also its says turn signal rear tail light does this matter
DRL bulbs are relatively easy to change (I can only speak for the H4 setup that I sadly have!), even on the driver's side, access is not bad. Removing the top of the air filter housing is easy and I do have to do that to change the H4 headlight bulb, but I don't think it would help much with a DRL bulb change.Morning all,
I've just had a bulb warning pop up on my van, looks like the DRL on the drivers side has gone, looking briefly at the space restrictions that side is it an airbox or headlight out job to get to these? is the common consensus to replace with LED bulbs? my main consideration would be if this is likely to last longer as they appear to be difficult to access.
