im starting to notice another possible issue during testing this single EHU charger method.
I've had the 15A charger connected for 24hrs. the starter battery is 100% and the AUX battery seems 100% full (according the the BMV)
The charger had moved from bulk, to Absorb, to float, to Storage.
this is the Victron charger showing storage mode after fully charging the system. . . . . . 100% full and holding at 13.2v
what I've noticed is that when the charger moves to storage mode of 12.6v - 13.2v (to keep the starter battery maintained)
its "below" the "AUTO VSR" point of the DC-DC charger . . . so the Renogy DC-DC is now showing that the RED ALT light is out . . . . so its now NOT charging the AUX battery.
to try and stir things up I've added a load to the AUX battery . . . . a 300W inverter and a Makita 18v charger for my drill battery.
its drawing about 5-10A and is starting to drop the AUX battery voltage & % . . .
as you can see here the EHU charger is not compensating for this draw as the DC-DC is effectively OFF and allowing the AUX battery to drain down independently and without being recharged . . . .
its just ticking over maintaining the starter battery @ 13.2v and 0.37A
ill charge up some batteries to see what happens . . . . .
But it looks like the only way to restart the cycle is to either RESTSART the EHU 15A charger (turn off/on)
Or
Cause a drop in the starter battery voltage to kick in the charger back into bulk mode . . . . (opening doors and interior lights made no difference . . . so maybe headlights?)
TBC:
heres an update 4hrs later, draining the AUX battery via the inverter . . .
the Renogy is showing a LOW AUX battery . .
after charging about 5 of these batteries . . .
The EHU charger is keeping the STARTER battery 100% and happy at 13.0v
but look at the AUX battery . . . . . . .
checking the specs . . . we see that the turn on point for the DC-DC is 13.2v. (13.2v AUTO VSR & 12v with IGN feed)
over here:
https://www.t6forum.com/threads/guide-dc-dc-charger-for-leisure-battery-how-i-done-it.15066/
so it looks like we are right on the tipping point . . .
The charger is set at 13.2v float/storage . . .
but with volt drop across the cables and connections . . . . we must be under the 13.2v trigger voltage to kick in the VSR function. . .
TBC:
testing the Starter battery voltage (at the battery) is 13.03v . . . (so we are loosing 0.2v from the charger)
and will most likely loosing another 0.2v across the cables to the Renogy DC-DC . . . .
So one option my be to tweek the setting on the Victron charger to increase the Float/Storage voltage from 13.2v up to 13.6v and see what happens....
TBC:
Yep that's solved that problem . . . . . =]
another +1 for the Victron chargers and the ability to change the parameters . . .
storage mode changed to 13.6v . . .
The DC-DC has kicked in and started charging the AUX battery again. (13.6v @ 4A)
here we can see the BM2 readout and voltage increasing . . . .
here we can see the AUX net effect of charging with a +2.75A (plus +2.6A the inverter is drawing)
So the final result is . . . .
Yes this works provided your main Starter EHU charger can keep the Starter battery voltage up high enough so that it is above the DC-DC AUTO VSR trigger voltage
TBC:
ill leave it running and update later . . . .
