This may have been covered before so excuse me if it has. My T6 had a set of new side bars fitted 3 years ago.
I’d noticed them rusting at either end for a while so thought I’d take them off and repaint or replace.
I was quite shocked to see how badly the have corroded. The brackets were a pain to remove as the nuts had rusted to the bolts on the attachment brackets, this meant they just span round instead of undoing. Ended up taking about two hours to get them stripped off, with lots of cussing and swearing. I’m not going to be fitting any more. The only bits to survive unscathed are the stainless clips, and zinc plated bits, for obvious reasons.
If you are going to fit some, use plenty of protective grease or rust preventer as you go, inside the ends of the tubes as well.
I should point out these were cheap bars, more expensive ones may well be more resistant.
