Long wet drive home from north england, check engine light came on. Pulled into service station, used carista to view problem. Anyone seen this before? - reset faults, hasn't appeared again since...
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
the ECM does not think your NOx reduction system is working the way it should, too much NOx is being detected.
Battery Regulator 02256 – quiescent current - Battery monitor detecting power drain from starter battery (about above 50mA) (left the Carista plugged in obd2 PORT overnight)
@Dellmassive ... you superstar, thanks!! ... I’m thinking none of this is a big problem... I’ve only got 30k on the clock, so I’ll make them aware next service
