Last summer our van started making some rotten clunking noises on uneven road surfaces (speed bumps were fine).
No surprise then that the drop links had failed. Local garage fitted some new ones and all was good.
Three momths later, clunking returned. Local garge took a look and noted that the passenger side drop link had already failed again. Replaced under warranty.
Come January and the clunking was back again. At this point I realised we had a bust front spring and tired shocks so we opted to replace springs, shocks top mounts etc all round. The garage also damaged the driver's side drop link while changing the shocks so that was renewed too.
So, pretty much an entirly new front end and yet, clunking is worse than ever..... I took the drop links off myself last weekend and they seemed fine but I wasn't sure about the ARB bushes.
My plan is to remove the drop links again this weekend, tie off the ARB and take it for a test drive. If the noise is gone then I guess it's the ARB bushes or, somehow, the drop links again. Given the hassle in doing this, I've ordered a set of Meyle HD drop links to fit since the ones the garage are using don't seem to be top quality.
Can anyone suggest any other checks I might want to do while I've got the van up on the jacks?
Thanks.
Thanks.
