COB Lighting for Halo Roof
8balladdict
VCDS User
Hi all.
Anyone have any ideas of the best COB lighting strips to use for a halo roof ambient lighting install? Want a full 270 degree continuos surround so probably 6ish meters and ideally strips that can bend 90 degrees on the corners when horizontal rather than ones that need to be cut….although if that’s the best option then so be it. Aware this will probably need powering from both ends but that’s fine. Any ideas?
I know that SCR have been using the COB led strips in van work they’ve done recently. Pete was showing me some when I picked up some speakers. Might be worth giving them a ring. He seems a helpful sort of bloke.
I’m looking at the Plyworks or Infinity Custom Halo style roof, on a SWB T6.1.
I know it’s been talked about before but what do people recommend to use for the LED’s in the roof?
I see most strips only come in 5m lengths, but I think I need 6m for a SWB?
Do and come with an option for the lights to change with sound?
