There was no filament lamps (it's T6.1), but Dellmassive seems to be saying the BCM will eat the 300mA for breakfast. If I find otherwise, I will add a MOSFET as you suggest, until then I will keep it simple. ThanksI can't comment on the current rating of the BCM other thanto say that it's rated for incandescent festoon bulbs, so if you've replaced those with LED bulbs then you shouldn't be exceeding the BCM current rating. If you wanted to be on the safe side you could replace the diode with another MOSFET switch module which would run in parallel with your MOSFET circuit. See attached diagram. That way there will be no appreciable load on the BCM
