Evening @Lozbetter to terminate the plug with a resistor. But you will need to clear the code with a VCDS/Carista/VCP/ODB11
Can I ask your advice please.
I've just fitted a swivel and the airbag light is now on... switched ignition on.....DOH...Does the resistor enable me to not connect the plug bag into the socket ? Does the plug need disconnecting every time I swivel the seat? Hence a resistor is needed?
Once the resistor is fitted, I assume a carista reset will sort.
Cheers. Dan
