F Friedrich New Member VIP Member 18 Sep 2023 #21 Hi, how did you mount the new wireless charging module ? Did you glue it with something or What did you do ? Thanks in advance!
J jinx82 New Member 11 Oct 2023 #22 @Robert I am also interested in how you have mounted new module? Can you please give us more info on that?
T th33xil3 New Member 15 Dec 2023 #23 Hallo @Rober, im trying to fit the module but it doesnt fit standard. Did you modified the bracket and glue it in ??
Robert Senior Modder from Poland VCDS User Moderator VIP Member T6 Legend 15 Dec 2023 #24 Initially I got my "new" charging unit only cable tied in place. But once I have satisfied my expectations I got it attached with epoxy resin.
T th33xil3 New Member 15 Dec 2023 #25 Ah okay and did you epoxy the printplate itself or leave it in the housing. You als have to break some mounting brackets I've im correct or not ?
Robert Senior Modder from Poland VCDS User Moderator VIP Member T6 Legend 16 Dec 2023 #26 I got complete unit attached with epoxy and whatever orginal plastic holder were in the way, I cut them off.
T th33xil3 New Member 16 Dec 2023 #27 Okay, and how is the charging working? Is it fast charge or moderate. Wil do the same thing.
Robert Senior Modder from Poland VCDS User Moderator VIP Member T6 Legend 16 Dec 2023 #28 Generally speaking wireless charging is slower than direct connection to the charger. So I would say moderate .
