New box arrived, same part number, connected and started all working straight away. I can map any button I want.
Thanks everyone for your help
So to summarise for anyone searching:
- van is a t6 eu6 late 2016 startline
- retrofitted later type MFSW with cruise on wheel
- basic startline cluster
- ctkvw017 kit used
- sony xav-ax3250 headunit
- no extra configuration or jumper switch changes needed (unlike what connects2 told me…)
- Universal patch lead included within the kit is wired identical to the CTSONYLEAD out of the box (although, I will say the universal one was less of a snug fit)
- on preset, volume works, and skip back, skip forward puts the screen to sleep
- all buttons can be mapped via custom (again connects2 support told me this was NOT possible for Sony) including phone and voice buttons, so now everything is good
- 5F error for multimedia (if originally fitted) will show, and a canbus error as the multimedia module will not be reaponding when removed, this cannot be cleared, but the buttons will not be disabled and should still function
- I didn’t see the point in removing 5F and coding in radio, you get one less error (none on cluster) but the others remain, and later if I ever did have any reason to refit factory unit, it will just work and not need to be coded back in
I’m a happy bunny seeing as I already went through the hassle of running wiring and rca leads etc specific to this unit and set up the sound and everything else how I wanted, so I will just use this unit for now.
@Dav-Tec and
@Absolut5 were correct, the wheel configuration did not matter, and thats a big sigh of relief, as for a moment, I thought I would be stuck!
