Cotek SP1000 Professional Pure Sine Wave Inverter 1000W
Top end inverter - Cotek are the manufactures, but also white labled as MASTERVOLT & ANTARES
brand new - never fitted in a van,
change of direction & need to buy a pop-top
used in service vans like British Gas etc,. . .
£350 collected + shipping.
The Cotek SP series 12Vdc to 230Vac pure sinewave power inverter is perfect for running mains powered equipment up to 1000 Watts from your deep cycle or commercial battery.
Designed for professional, industrial, marine and applications to power more difficult loads such as refrigerators, air conditioning units, fluorescent lamps and appliances that use a motor, these inverters provide the highest quality sinewave 230V AC output from 12VDC batteries.
All Cotek inverters come with 2 year warranty as standard.
Features
- Pure Sinewave Output (THD<3%)
- Output frequency: 50/60Hz switch selectable
- Wide input range of 10.5V to 16.5V for use with smart alternator systems
- Low Profile design
- Input/Output fully isolated
- Low power “Power Saving Mode” to conserve energy
- High Efficiency: >90%
- Capable of driving highly reactive and capacitive loads at start up
- Tri-colour indicators display input voltage and output voltage level
- Loading controlled cooling fan
- Advanced microprocessor
- Protection: Input low voltage, overload, over temperature and reverse polarity
- E-13 / UL / CE /FCC approved
- Pt No.: PPT2112
- Input: DC 10.5V-15V
- Output Voltage: 230Vac (+- 3%)
- Output Power: 1000W continuous
- Dimensions: 372mm x 200mm x 83mm
- Weight: 3.3 Kg
- Inductive loads
- Audio equipment
- Lighting
- Professional solutions
- Small refrigerators and ovens
- Power tools
- Computers
- Loads up to 1000W
- Heavy Duty crimping tools
- Cable stripping tool
- Cable crimpers
- Soldering iron and solder
- Digital multimeter
- 3 metres of both black and red extra flexible battery cable
- 10 x Copper stop end terminals
- 2 x Battery terminals with 8mm studs
- Mega fuse and mega fuse holder (150 amp rating depending on requirements)
- Cable ties, P-clips, cable ties, insulated spade terminals, insulation tape and conduit.
pics:
