andrewburtenshaw
I've had my 2018 T6 in at the garage with some noise, vibration and steering issues that started suddenly last Monday:
- Wandering steering
- Creaking from the front end when steering
- Cabin vibrations
- Creaking when rocking the van side to side
The garage found n/s/f track rod end play and o/s/r coil spring broken. They've replaced the coil spring and the track rod end and done the wheel alignment. The steering has improved, but I'm still getting the creaking noises from the front end when steering at low speeds and if I rock the van side to side, and I'm getting clattering vibrations in the cabin.
One of the things I noticed in the paperwork was an advisory note after doing the work that says "slight play in rack end". Anyone know what that means and if it could be the cause of the remaining front end symptoms I'm getting? The creaking only starts after about 15 minutes of driving the van. I'm going to be taking it back in, obviously, but the creaking noise was not present when I left the garage this evening and wasn't present when the garage were investigating. It came back within about 15 minutes of leaving!
Noise when steering: IMG_4703.MOV
Noise when rocking: IMG_4708.MOV
- Cabin vibrations
