I like the look of this. My main gripe with my otherwise fab Dometic awning is that it's fitted to the side of the van, and when it rains there's a small gap between the awning and the van that water drips through onto the steps and in the open side door. I've run a length of foam quite snugly down the gap, which has helped, but it's not watertight by any means.Amazing service from agentfiamma.com
Ordered a Fiamma F40 Van Awning and fitting kit on Friday lunch time. Arrived this morning!
Very impressed with the quality of the Fiamma. Fitting was super simple and fast. We t from two boxes to a fitted awning in 15 minutes. I’ll report on the awning....once it stops pouring with rain!
So with the Fiamma F40, is there a gap between the awning and the van, or does it sit on the roof far enough so that no water runs down?
Thanks.
P.S. Anyone got a clever fix for plugging my gap between my awning and my van?
An expensive fix. Would the Fiamma Rain Guard fit your Dometic?I like the look of this. My main gripe with my otherwise fab Dometic awning is that it's fitted to the side of the van, and when it rains there's a small gap between the awning and the van that water drips through onto the steps and in the open side door. I've run a length of foam quite snugly down the gap, which has helped, but it's not watertight by any means.
Thanks.
I've got one on my side elevator, there's a few pics of others on here with normal pop-tops, I'll search them out laterThanks, yes I've looked at those before, but I think they are designed for roofs that don't lift up...?
I've got one on my side elevator, there's a few pics of others on here with normal pop-tops, I'll search them out later![]()
I take it there is some type of theft prevention on it? Quite fancy one myself.
I didn't know there was an awning you could bolt on using the roof rail screws, that's excellent for ease of fitting and removal. Only downside is it makes the van that bit taller (I need to get into height restricted car parks)
What would be the benefit of lock wiring? I guess it's more faff, but it's not more secure is it? Only really stops them from falling out from vibration...?
Loving your build crispy! are you going to add a solar panel to your Yeti?
