I need to confirm this although I believe it will. I cleared it last time but tested that the ghost was working before I checked it was still cleared so put the error straight back onIf you clear it does it stay cleared
Just the error code 9456128, engine signal error or something which I think is received only when you try and start the engine without entering the correct code (going by searches, I need to test to be sure)
Ah right, I see. I thought you meant that it generically shows a code, rather than it shows a code when used geriatrically.I can confirm that Ghost definitely causes errors to be logged if you try and start the van without the code. I've done it plenty of times
