Cruise Control Retrofit Euro5
Hello,
I contacted kufatec to buy a cruise control kit to my 2016 VW T6 (Euro 5, without rear wipers, BCM ***-937-090-***) since many people here buy it there.
He told me it's not possible to fit the cruise control via stalk because I have a Multifunction steering wheel (here is a picture), is it true ?
And that I must buy this version for Multifunction steering wheel at 450€ !!?
Anyone here managed to add cuise control on stalk on a T6 euro 5 with Multifunction steering wheel ?
I think it is possible since somes sellers like the one I was talking yesterday here : Tempomat GRA Nachrüstsatz für VW T6 7E ab BJ. 2015 have the option "Multifunction steering wheel / with OR without" and the final price is 159€ (I think I don't need the MFA option on this link that add the trip button if I understand weel, on the right stalk, since I already have on my steering wheel this button).
Thank you !
We have done many genuine cruise control Installs with stalk and with that wheel you have … many vans came with the same setup from factory
Reactions: mmi
Thank you both for your responses.
Yes I've checked this topic but since it's for euro 6 I'm not sure it concern me.
I've told kufatec it's possible since others sellers say it is and here is his response :
Thank you for your request.
We are retrofitting the cruise control how it would be ex factory installed. If your car has a multfunction steering wheel the cruise control will be controlled through the buttons of the multifunction steering wheel buttons.
Regarding the retrofit of the other company we can not say something, but it is not the same like it would be ex factory
He just want to sell the expensive version of the cruise control that goes on the wheel...
I'm quite sure the stalk for T5.2 is compatible with the T6 euro 5 when I see this on ebay Genuine VW Transporter T5.2 T6 Cruise Control Kit - No Rear Wiper / Without TRIP | eBay
And kufatec has this version too here if I'm not mistaken KUFATEC cruise control set for T5 Without rear wiper, without MFD, from 04.11.2013
The price is the same as the link I posted this afternoon here from the other seller : Tempomat GRA Nachrüstsatz für VW T6 7E ab BJ. 2015
For the VCDS modification I've founded someone that have the real version that will make the modification for me :) it's better than having a clone one.
Hello !
I've finally managed to do the cable modification on my T6 euro 5 with stalk.
Now I have a problem with coding.
I have to activate with VCDS but I can't do it like the seller told me (entering 11463 in the menu 11 since I can't clic on it, It's because I am in long coding I think !)
How do I activate it with long coding ?
I search by myself and what I did is that :
I went on 08 - Coding, then pressed long coding helper, went on byte 5 (number 06) where it was selected 00 - cruise control system (ccs) not activated, and I choosed the value 20 - ccs activated.
It just changed the whole code by replacing 06 by 26. I saved, but it's not working, when I put the ccs switch in the on position, there is no light ?
I checked the long code once again, it's the on with my modification.
Can someone help me ?
Thank you !
I also tried to go to 09 - electrical central -> coding - 07 and went to byte 17 and checked cruise control system (ccs) installed but it's still the same :(
You are touching right parts...
Please post 1) a full Auto-Scan before any coding, and 2) current Auto-Scan.
You can monitor status of the Cruise Control switches:
IGN ON
09-Centr.Electr. > Adv.Meas.Values >
Tick the following​
  • Cruise Control Main Switch
  • Cruise Control Cancel Switch
  • Cruise Control SET/Decelerate
  • Cruise Control RESET/Accelerate
Play with the switches and verify the measured values follow...​
Thank you ! I have no error in the auto scan.
I tried the Adv.Meas.Values and I only have the reset/accelerate who is changing statut when the main switch is on the ON position. But the main switch is always at "off" on VCDS even when it's on :/
Just wanted to compare the codings with known ones.
oh okay, so here it is (I had founded one error at last but after erasing it, it's not here anymore).
I'm wondering if there is a problem with the cables or not. I've done the cables very carefully and had no problem with the colors and the numbers.
I'm wondering if I pushed enough the cables, I heard some "clic" noise and the cables won't come back so I thought it was okay.PXL_20211129_154017471.jpg
01-Engine - Status: Fault 0010
03-ABS brakes - Status: OK 0000
04-Steering angle - Status: OK 0000
08-Climatronic - Status: OK 0000
09-Centrale Elec. - Status: OK 0000
10-Park assistance - Status: OK 0000
15-Airbags - Status: OK 0000
17-Instruments - Status: OK 0000
18-Heat. back-up - Status: OK 0000
19-Gateway CAN - Status: OK 0000
22-Transm. full - Status: OK 0000
25-Immobilizer - Status: OK 0000
5F-Electr. informat. - Status: OK 0000
61-Reg. battery - Status: OK 0000
Address 01: Engine (J623-CAAC) Labels :. 03L-906-022-CAA.clb
Log part no .: 03L 906 019 GR Mat: 03L 907 309 L
Component: R4 2.0L EDC H38 8434
Revision: 22H38 --- Serial number: 00000000000000 CVN: 2B514BAD
Coding: 0119401A232601080000
Workshop number: WSC 02737 790 50316
ASAM dataset: EV_ECM20TDI01103L906019GR 003005
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 01093003900903814A-8054
VINID: 9E606AAAA1D8A976002462440026ADA622
1 Fault code found:
4482 - Limited operation due to implausible message
U1112 00 [032] - -
Intermittent - Not Confirmed - Tested from Memory Reset
Capture:
Fault state: 00000001
Fault priority: 2
Fault frequency: 2
Mileage: 125,347 km
Date: 2021.12.15
Time: 02:08:53
Engine speed: 865.00 / min
Standardized load value: 25.5%
Vehicle speed: 0 km / h
Coolant temperature: 46 ° C
Intake air temperature: 18 ° C
Ambient air pressure: 1020 mbar
Terminal 30 voltage: 14.620 V
OBD unlearn counter: 40
Cruise Control: Command Position-Bits 0-7: 64
Cruise Control: Status-Bits 0-7: 200
Power regulator cut. irreversible-Bits 0-7: 0
Power regulator cut. Reversible-Bits 0-7: 255
Speed regulator: set speed: 0.00 km / h
Engine ECU Reset Status-Bits 0-7: 0
Power regulator cut. irreversible with brake intervention-Bits 0-7: 1
Tests passed: 0 0 0 0 1
Address 03: Brakes ABS (J104) Labels: 7E0-907-37x-MK100ESC.clb
Log part no .: 7E0 907 379 P Mat: 7E0 907 379 M
Room: ESC H05 0132
Revision: 00000000 Serial number: 40196000000476
Coding: 347E8098256B84842C7E017AA4822193380000
Workshop number: WSC 02739 790 50316
ASAM dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8DF6FBA67DB5717C-806A
No fault code found.
Address 04: Direction angle (G085) Labels: * 6R0-959-654.clb
Log part no .: 6R0 959 654 Mat: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 13011613472329
Coding: 01
Workshop number: WSC 00000 000 00000
ASAM dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7937-802A
Address 08: Climatronic (J301) Labels: | 7E5-907-047.clb
Part number Log: 7E0 907 047 AK Mat: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73E56ACBDAB5211148-8026
Address 09: Centrale Elec. (J519) Labels :. 7E0-937-BCM-V1.clb
Log part no .: 7E0 937 090 Mat: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 018161750
Coding: A0A0303A0A6134B3922849746C2B8C548FA0708F60CE4D60320400220800
Workshop number: WSC 02737 534 159001
VCID: 68DF0DA79B73D2C9ED-803C
Subsystem 1 - Log part no .: 7E0 959 801 J Mat: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU019011660191568
Coding: 0400A1
Subsystem 2 - Log part no .: 7E0 959 802 J Mat: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Room: J387__TSG_BT 003 8654
Serial number: KU0KU007011660075249
Coding: 1400A1
Subsystem 3 - Part No .: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No .: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Reactions: mmi
It's now working I think (don't have the time to test it) but I checked all my cables by removing the steering wheel and I managed to push even more the ones we saw on my picture just near the stalk, and now on VCDS all 4 button are working :) and when I put it on, on the dashboard it shows me it's on :)
