I remember that day, it was a great one. Picked @Fish up with daughter Fish, went to the Daventry Country Park, had a picnic and fed the ducks. Awesome.
So, Fish, how is it working? Ever run out of 12 volt power at a festival? Has it killed your battery yet?
@travelvolts having nightmare again, close to chinning the ctek off.. can't get to the bottom of the issues..
battery charges doesn't recognise any battery when connected direct on hook up.
Leisure batteries dont charge over 12.5.
Think ctek have cooked another set off batteries.
great vid =]I remember that day, it was a great one. Picked @Fish up with daughter Fish, went to the Daventry Country Park, had a picnic and fed the ducks. Awesome.![]()
Yep it was replaced, faulty unit... all seems to be fine atm.Did you ever get to the bottom of this as I have just purchased the d250sa and never had an issue with my starter battery and now sometimes even as I drive and stop for fuel there is not enough power in starter to start engine again but the leisure battery is charging great
Have you got a dodgy Moll EFB battery ?Did you ever get to the bottom of this as I have just purchased the d250sa and never had an issue with my starter battery and now sometimes even as I drive and stop for fuel there is not enough power in starter to start engine again but the leisure battery is charging great
The Ctek shouldn't be drawing current if the ignition is offNew update I ended up replacing my starter Battery with a Bosch s5 and today I have had to replace it again as it’s no longer holding charge so the CTEK is still drawing current even when the starter drops below 12.5 volts not sure what to do
I have bought the smartpass yesterday also so when I fit all the new bits maybe that will solve the issue
Just getting expensive![]()
