Ah ok, thanks. I assumed it would be similar to service battery and run at 14.2v ish13.6v is normal for the battery as it's charging up.
You will only see 14.2v as it's 95% or more full.
It will take hours on the d250, it's about 25A max charge rate...so Will take a few hours to raise a new battery from 50% up to fully charged.
I was confused by this before installation, did some research and saw this video where he seems to point to the battery + out. I'll try swapping it, thanks!
That vid...I was confused by this before installation, did some research and saw this video where he seems to point to the battery + out. I'll try swapping it, thanks!
@ 2 minutes in;
