I'm confused now as you've described the ignition wire both as red and black.
I would double check as soon as possible that the RED wire is connected to ignition so it selects smart alternator and BLACK wire is connected to +12v to select lithium profile.
If you have them back to front your charger is trying to switch between profiles every time you turn the ignition on and off and may be running with ignition off.
