Square Peg
Having recently spent 4 nights away in the van, parked up but with EHU for the leisure side of things, we suffered from the dreaded low battery warning when starting the engine to come home.
Having spent much time reading various threads here, I purchased the MXS 5.0 trickle charger. I took note of the advice here re using a chassis ground point for the negative lead, and fired it up.
The charger reached stage 3 quickly, and then took about 4 hours to reach stage 4. At this point, I noticed the D250 was charging the leisure battery, and again, reading threads here that seems normal.... so no worries there.
However, with the battery probably being the original (20 plate T6.1, 70Ah EFB+) it might be close to the end of it's life. Before splurging out on a new one however, I'm thinking about using the recondition mode on the MXS 5, which might be beneficial.
I do wonder though if using that mode could cause problems to the D250se and/or the leisure battery (Yuasa L35-115), as I understand the max voltage in the recon mode is 15.8 volts. If anyone can say good idea or not, I'd appreciate it.
I do have the Victron Smart Solar MPPT 75/15 and Victron 12117 charger for the leisure side, which both work fine, so I'm considering getting the Ablemail AMT12-2 at a later date, having read glowing reports here too.
