Ctek MXS 5.0 and Ctek D250se
Having recently spent 4 nights away in the van, parked up but with EHU for the leisure side of things, we suffered from the dreaded low battery warning when starting the engine to come home.
Having spent much time reading various threads here, I purchased the MXS 5.0 trickle charger. I took note of the advice here re using a chassis ground point for the negative lead, and fired it up.
The charger reached stage 3 quickly, and then took about 4 hours to reach stage 4. At this point, I noticed the D250 was charging the leisure battery, and again, reading threads here that seems normal.... so no worries there.
However, with the battery probably being the original (20 plate T6.1, 70Ah EFB+) it might be close to the end of it's life. Before splurging out on a new one however, I'm thinking about using the recondition mode on the MXS 5, which might be beneficial.
I do wonder though if using that mode could cause problems to the D250se and/or the leisure battery (Yuasa L35-115), as I understand the max voltage in the recon mode is 15.8 volts. If anyone can say good idea or not, I'd appreciate it.
I do have the Victron Smart Solar MPPT 75/15 and Victron 12117 charger for the leisure side, which both work fine, so I'm considering getting the Ablemail AMT12-2 at a later date, having read glowing reports here too.
The MX5 is a good charger..
The auto VSR feature on the Dc-Dc is normal. Most do it.
When camping have the MX5 connected to the starter..
Many thanks for the above links. I must say it was from reading your advice and recommendations on the forum that I bought it.... so many thanks for the time and effort you take to post the technical stuff. :cool:
I have a '20 T6.1, my original EFB 70Ah battery was showing signs of dying at around 4 years old, I put a bigger Bosch AGM 95Ah in and coded it with Carista. At the same time I put in the AMT12-2 and haven't had starter battery anxiety since. I still carry an MXS5 just in case, it's been used twice, on other folks vans!
New battery, Ablemail, more money, no stress!
I'm seriously considering the Ablemail, but will need to save up a few more pennies first. I see why everyone calls these vans moneypits though. :D
I put the MXS 5.0 on again this morning, and it reached stage 4 within about 5 or 10 minutes. It's now reached stage 7, having passed the stage 5 check, so there's hope that the battery will last a bit longer. I haven't tried the cigar lighter plug route as yet but I'm optomistic now.
With the season approaching I would certainly consider the possibility of going into debt to fund a new battery, and it may be that @Dellmassive has a spare AMT12-2 available for purchase, so I've heard on the vine full of grapes...
For context my current chargers are mostly CTEK and I use the same one to keep the van topped up via the towing socket.
The "recon" mode is really only to try and rescue a traditional flooded battery by causing the electrolyte to deliberately form gas bubbles on the plates and maybe that action will clean the plate. On an AGM the electrolyte is held in place by the glass fibre matt so this is likely not a very good idea, there may be some very minor benefit in an EFB.
However, despite what might be claimed/hoped, if the battery has been damaged by age/deep discharge any such recon process is not going to recover the battery to what it was and it would be very temporary. It's worth trying if you are stranded and need to battery to work a few days more to get home and it replaced, it's not something that's going to give you another season of use.
The van is in for seevice and MOT on monday at my local VW service centre (we got the extended warranty and prepaid MOT's just after getting the van), so might ask them to test the battery at the same time. I might give the reconditioning ago at the weekend and see what happens.
Honestly if you are already suspicious of the health and it's in somewhere consider just get it replaced with a known good battery.
They're very much consumables in modern vans with a life of 3-5 years - and they cost about as much as a full tank of fuel.
Knowing how much people like photos of various electical set ups, here's one of my mine taken this morning after adding the AMT 12-2. I know I should really tidy up all the connections to the positive terminal on the battery by adding a bus bar, but that's a job for another day.
Kit as below.....
Yuasa L35-115 battery.
Victron Blue Smart Charger 12117.
Victron Smart Solar MPPT 75/15.
CTEK D250 SE.
The shunt is for an AiLi battery monitor.
50A circuit breaker.
Fuses.
Ablemail AMT12-2.
All criticism or suggestions welcome.... ;)
