Thanks But What can do this codes when you have replace Egr?P1010 mass airflow sensor fault
P0402 EGR excessive flow.
How did i do that?Did you set up the EGR valve according to VW procedure after installation?
DiYWas the EGR cooler replacement done by a garage or was it DiY?
Ok so you dont Think is a calibrations basic setting problem ?
I cant find in autodata What value the Maf should have
