Dashboard alignment :(
T6DSGChris
How many of you will now go out and check yours!?
my dash is on the pish.
fitted the cool retrofit softlight kit in the ceiling, the trims on the right were just a bit too baggy.. so you start looking...
Question.. as theres the obvious 4 nuts on the outer edges of dash.. wheres the internals so i can tease it across to sort my Inner ying yang
This shows what i mean a little better. when you sit in your drivers seat and check finger gaps mines a good few mm off to the left. "commercial vehicle" tehe
Hi Chris, that's a slight off with the dash......glad to see the cabin light arrived...looks ace.....are you pleased?....Matt
yeah its worse in reality to the pics tbh... really annoying. I blame you entirely for me spotting it...:p I just went...why are these not fitting snug...went other side..tight as....went back... ya bugger ya... i will sort...just annoying!
the light kit was spot on mi old..like it a lot... ps there's two grey blues but i twigged which to use..i put led bulbs in but i may get some a little less...bright!
any ideas for the big hole in the roof...?
