Can I ask what sort of towbar you have? Is it fixed or removable? Could u post a pic of the mounting please? Cheers
I have ordered a Dave Cooper rack to carry a Honda Grom. He recommended the flange type tow bar which has 2 bolts to hold the tow ball. Just undo the bolts and sandwich the holding bracket with 2 longer bolts. Tow trust has been recommended.Hi yep I was recomended bak-rak by Dave Cooper (email below) I've not tried it in anger yet but have a competion Sunday so hope to give it a go.....
"Yes we can supply a rack but you will also need a BAK RAK swan neck converter
Dave"
I just ordered my Dave Cooper rack to fit with a Tow-trust flange tow bar to carry a Honda Grom. How easy is to lift the bike onto the rack considering my bike is 100kgs????. I am guessing front wheel first technique?
Hi, this is exactly the setup I’m looking at, just wondering how you’re getting on with it, any problems ? Would you recommend it
Hi Yep its been fine, use it most weekends since fitting, I got the tie down straps with it but cut the "hooks" off and fitted gated climbing carabiners so there was no chance of them coming off with any "bounce" and have played about with how to tie it down. As my van is now a camper with rear window my concern was the bike touching the window under heavy braking, I'll be putting the bike on tommorrow for the scarborough two day trial so if you want I can send you some photos of how I strap it.Hi, this is exactly the setup I’m looking at, just wondering how you’re getting on with it, any problems ? Would you recommend it
I also modified the light board so it clips on to the rack easily without having to tie it to the bikeHi Yep its been fine, use it most weekends since fitting, I got the tie down straps with it but cut the "hooks" off and fitted gated climbing carabiners so there was no chance of them coming off with any "bounce" and have played about with how to tie it down. As my van is now a camper with rear window my concern was the bike touching the window under heavy braking, I'll be putting the bike on tommorrow for the scarborough two day trial so if you want I can send you some photos of how I strap it.
enjoy
