Deadlocks / Safelock not working on our T6
GavMc P11GT
So as the title suggests we seem to have no deadlocks on the van! They used to work!! there’s various VCDS tweaks been done while we have had the van just the usual stuff needle sweep etc
We have been through all the long coding helper and cannot see anything untoward!
Any clues?
If I lock the door with one press they used to work now they don’t, they lock but only without deadlocking
It’s a 2016 66 Highline
I had this problem abs as I recall it was to do with me disconnecting the battery.
On connecting the battery I had to reset the click the button once for the windows to go all the way. This solved my deadlocks not working.
Once you get the leads off the battery touch them together for a few seconds before connecting back to the battery. This is supposed to be a reset of some type.
Please post (1) full VCDS Auto-Scan + (2) adaptation map from the BCM (address 09).
Sorry for the late reply been on holiday just catching up! See below I think I have what you asked for!
Code:
VIN: WV1ZZZ7HZHH005647   License Plate:
Mileage: 160170km-99525mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHH005647   Mileage: 160170km-99525miles
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114014432401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 76E353DFC9C7343639-8022
2 Faults Found:
29972 - Coolant Pump for EGR
          P24A8 00 [039] - Performance too Low or Stuck
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 160120 km
                    Date: 2067.01.31
                    Time: 12:48:46
                    Engine speed: 818.50 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 23 °C
                    Intake air temperature: 17 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 14.601 V
                    Air mass at air mass meter 1: 39.6 kg/h
                    Standardised airflow ratio: 1.229 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 23.98 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 1.234 bar
                    Absolute intake pressure: 107 kPa abs
                    Mean injection quantity: 12 mg/stroke
                    Index of current engine mode: 0
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
15560 - EGR Sensor 1
          P046C 00 [104] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 160105 km
                    Date: 2067.01.26
                    Time: 06:21:58
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.328 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: -0.88 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 17.10 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.: 0.00 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.608 V
                    EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.439 V
                    EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.592 V
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 41346000000259
   Coding: 517E4098256284838A7B027AA48921E6790000
   Shop #: WSC 02739 790 50316
   VCID: 3F8DF6FBA67DB57E2A-806A
No fault code found.
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 23051613471124
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7661-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73E56ACBDAB5211E1E-8026
1 Fault Found:
9481200 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Date: 2022.05.26
                    Time: 14:19:21
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 148161037
   Coding: BEA430BA0A61343193284FF46EAB9E75FF8470FF60CC6DF0320400220840
   Shop #: WSC 02737 022 222636
   VCID: 2A5BB7AF45FF20D66D-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 310516 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU010051661310757
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU027051661486106
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160000829790076172
   Coding: B0FFFF
3 Faults Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 31
                    Reset counter: 2
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.13
                    Time: 06:17:06
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.16
                    Time: 14:19:28
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 0
                    Mileage: 160108 km
                    Time Indication: 0
                    Date: 2016.10.17
                    Time: 05:26:36
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32961609701401
   Coding: 10800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 4385FA0BCA95D19E4E-8016
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3000Z2L9
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A7B87EFBD5F90561D-806E
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1104
   Serial number: 00000000000000
   Coding: 750B220300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
1 Fault Found:
13654544 - Databus
          U1121 00 [009] - Missing Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 47
                    Reset counter: 218
                    Mileage: 160105 km
                    Date: 2022.05.23
                    Time: 06:17:04
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68DF0DA79B73D2C6BB-803C
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.13
                    Time: 06:17:11
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1104
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6AD-803E
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001605200592
End-------------------------(Elapsed Time: 03:25)--------------------------
Code:
ChannelField 1Field 2Field 3Field 410N/AN/AN/AN/A2ERROR:
Channel 02
NotAvailable31N/AN/AN/AN/A41N/AN/AN/AN/A51N/AN/AN/AN/A60N/AN/AN/AN/A70N/AN/AN/AN/A81N/AN/AN/AN/A90N/AN/AN/AN/A100N/AN/AN/AN/A110N/AN/AN/AN/A121N/AN/AN/AN/A131N/AN/AN/AN/A140N/AN/AN/AN/A150N/AN/AN/AN/A16ERROR:
Channel 16
NotAvailable17ERROR:
Channel 17
NotAvailable18ERROR:
Channel 18
NotAvailable19ERROR:
Channel 19
NotAvailable201N/AN/AN/AN/A21ERROR:
Channel 21
NotAvailable221N/AN/AN/AN/A231N/AN/AN/AN/A240N/AN/AN/AN/A251N/AN/AN/AN/A26ERROR:
Channel 26
NotAvailable270N/AN/AN/AN/A281N/AN/AN/AN/A291N/AN/AN/AN/A302N/AN/AN/AN/A310N/AN/AN/AN/A3240N/AN/AN/AN/A3380N/AN/AN/AN/A3430N/AN/AN/AN/A352N/AN/AN/AN/A362N/AN/AN/AN/A3780N/AN/AN/AN/A3821N/AN/AN/AN/A3915N/AN/AN/AN/A4014N/AN/AN/AN/A4120N/AN/AN/AN/A4210N/AN/AN/AN/A433N/AN/AN/AN/A445N/AN/AN/AN/A4580N/AN/AN/AN/A461N/AN/AN/AN/A4715N/AN/AN/AN/A4815N/AN/AN/AN/A49ERROR:
Channel 49
NotAvailable500N/AN/AN/AN/A510N/AN/AN/AN/A520N/AN/AN/AN/A530N/AN/AN/AN/A541N/AN/AN/AN/A551N/AN/AN/AN/A560N/AN/AN/AN/A570N/AN/AN/AN/A580N/AN/AN/AN/A591N/AN/AN/AN/A60180N/AN/AN/AN/A61200N/AN/AN/AN/A625N/AN/AN/AN/A6386N/AN/AN/AN/A641N/AN/AN/AN/A651N/AN/AN/AN/A662N/AN/AN/AN/A6724N/AN/AN/AN/A681N/AN/AN/AN/A690N/AN/AN/AN/A7020N/AN/AN/AN/A710N/AN/AN/AN/A721N/AN/AN/AN/A730N/AN/AN/AN/A740N/AN/AN/AN/A750N/AN/AN/AN/A760N/AN/AN/AN/A770N/AN/AN/AN/A780N/AN/AN/AN/A79255N/AN/AN/AN/A800N/AN/AN/AN/A810N/AN/AN/AN/A820N/AN/AN/AN/A830N/AN/AN/AN/A840N/AN/AN/AN/A850N/AN/AN/AN/A860N/AN/AN/AN/A870N/AN/AN/AN/A880N/AN/AN/AN/A890N/AN/AN/AN/A900N/AN/AN/AN/A910N/AN/AN/AN/A920N/AN/AN/AN/A930N/AN/AN/AN/A940N/AN/AN/AN/A950N/AN/AN/AN/A960N/AN/AN/AN/A970N/AN/AN/AN/A98ERROR:
Channel 98
NotAvailable990N/AN/AN/AN/A100ERROR:
Channel 100
NotAvailable101ERROR:
Channel 101
NotAvailable102ERROR:
Channel 102
NotAvailable103ERROR:
Channel 103
NotAvailable104ERROR:
Channel 104
NotAvailable105ERROR:
Channel 105
NotAvailable106ERROR:
Channel 106
NotAvailable107ERROR:
Channel 107
NotAvailable108ERROR:
Channel 108
NotAvailable109ERROR:
Channel 109
NotAvailable110ERROR:
Channel 110
NotAvailable111ERROR:
Channel 111
NotAvailable112ERROR:
Channel 112
NotAvailable113ERROR:
Channel 113
NotAvailable114ERROR:
Channel 114
NotAvailable115ERROR:
Channel 115
NotAvailable116ERROR:
Channel 116
NotAvailable117ERROR:
Channel 117
NotAvailable118ERROR:
Channel 118
NotAvailable119ERROR:
Channel 119
NotAvailable120ERROR:
Channel 120
NotAvailable121ERROR:
Channel 121
NotAvailable122ERROR:
Channel 122
NotAvailable123ERROR:
Channel 123
NotAvailable124ERROR:
Channel 124
NotAvailable125ERROR:
Channel 125
NotAvailable126ERROR:
Channel 126
NotAvailable127ERROR:
Channel 127
NotAvailable128ERROR:
Channel 128
NotAvailable129ERROR:
Channel 129
NotAvailable130ERROR:
Channel 130
NotAvailable131ERROR:
Channel 131
NotAvailable132ERROR:
Channel 132
NotAvailable133ERROR:
Channel 133
NotAvailable134ERROR:
Channel 134
NotAvailable135ERROR:
Channel 135
NotAvailable136ERROR:
Channel 136
NotAvailable137ERROR:
Channel 137
NotAvailable138ERROR:
Channel 138
NotAvailable139ERROR:
Channel 139
NotAvailable140ERROR:
Channel 140
NotAvailable141ERROR:
Channel 141
NotAvailable142ERROR:
Channel 142
NotAvailable143ERROR:
Channel 143
NotAvailable144ERROR:
Channel 144
NotAvailable145ERROR:
Channel 145
NotAvailable146ERROR:
Channel 146
NotAvailable147ERROR:
Channel 147
NotAvailable148ERROR:
Channel 148
NotAvailable149ERROR:
Channel 149
NotAvailable150ERROR:
Channel 150
NotAvailable151ERROR:
Channel 151
NotAvailable152ERROR:
Channel 152
NotAvailable153ERROR:
Channel 153
NotAvailable154ERROR:
Channel 154
NotAvailable155ERROR:
Channel 155
NotAvailable156ERROR:
Channel 156
NotAvailable157ERROR:
Channel 157
NotAvailable158ERROR:
Channel 158
NotAvailable159ERROR:
Channel 159
NotAvailable160ERROR:
Channel 160
NotAvailable161ERROR:
Channel 161
NotAvailable162ERROR:
Channel 162
NotAvailable163ERROR:
Channel 163
NotAvailable164ERROR:
Channel 164
NotAvailable165ERROR:
Channel 165
NotAvailable166ERROR:
Channel 166
NotAvailable167ERROR:
Channel 167
NotAvailable168ERROR:
Channel 168
NotAvailable169ERROR:
Channel 169
NotAvailable170ERROR:
Channel 170
NotAvailable171ERROR:
Channel 171
NotAvailable172ERROR:
Channel 172
NotAvailable173ERROR:
Channel 173
NotAvailable174ERROR:
Channel 174
NotAvailable175ERROR:
Channel 175
NotAvailable176ERROR:
Channel 176
NotAvailable177ERROR:
Channel 177
NotAvailable178ERROR:
Channel 178
NotAvailable179ERROR:
Channel 179
NotAvailable180ERROR:
Channel 180
NotAvailable181ERROR:
Channel 181
NotAvailable182ERROR:
Channel 182
NotAvailable183ERROR:
Channel 183
NotAvailable184ERROR:
Channel 184
NotAvailable185ERROR:
Channel 185
NotAvailable186ERROR:
Channel 186
NotAvailable187ERROR:
Channel 187
NotAvailable188ERROR:
Channel 188
NotAvailable189ERROR:
Channel 189
NotAvailable190ERROR:
Channel 190
NotAvailable191ERROR:
Channel 191
NotAvailable192ERROR:
Channel 192
NotAvailable193ERROR:
Channel 193
NotAvailable194ERROR:
Channel 194
NotAvailable195ERROR:
Channel 195
NotAvailable196ERROR:
Channel 196
NotAvailable197ERROR:
Channel 197
NotAvailable198ERROR:
Channel 198
NotAvailable199ERROR:
Channel 199
NotAvailable200ERROR:
Channel 200
NotAvailable201ERROR:
Channel 201
NotAvailable202ERROR:
Channel 202
NotAvailable203ERROR:
Channel 203
NotAvailable204ERROR:
Channel 204
NotAvailable205ERROR:
Channel 205
NotAvailable206ERROR:
Channel 206
NotAvailable207ERROR:
Channel 207
NotAvailable208ERROR:
Channel 208
NotAvailable209ERROR:
Channel 209
NotAvailable210ERROR:
Channel 210
NotAvailable211ERROR:
Channel 211
NotAvailable212ERROR:
Channel 212
NotAvailable213ERROR:
Channel 213
NotAvailable214ERROR:
Channel 214
NotAvailable215ERROR:
Channel 215
NotAvailable216ERROR:
Channel 216
NotAvailable217ERROR:
Channel 217
NotAvailable218ERROR:
Channel 218
NotAvailable219ERROR:
Channel 219
NotAvailable220ERROR:
Channel 220
NotAvailable221ERROR:
Channel 221
NotAvailable222ERROR:
Channel 222
NotAvailable223ERROR:
Channel 223
NotAvailable224ERROR:
Channel 224
NotAvailable225ERROR:
Channel 225
NotAvailable226ERROR:
Channel 226
NotAvailable227ERROR:
Channel 227
NotAvailable228ERROR:
Channel 228
NotAvailable229ERROR:
Channel 229
NotAvailable230ERROR:
Channel 230
NotAvailable231ERROR:
Channel 231
NotAvailable232ERROR:
Channel 232
NotAvailable233ERROR:
Channel 233
NotAvailable234ERROR:
Channel 234
NotAvailable235ERROR:
Channel 235
NotAvailable236ERROR:
Channel 236
NotAvailable237ERROR:
Channel 237
NotAvailable238ERROR:
Channel 238
NotAvailable239ERROR:
Channel 239
NotAvailable240ERROR:
Channel 240
NotAvailable241ERROR:
Channel 241
NotAvailable242ERROR:
Channel 242
NotAvailable243ERROR:
Channel 243
NotAvailable244ERROR:
Channel 244
NotAvailable245ERROR:
Channel 245
NotAvailable246ERROR:
Channel 246
NotAvailable247ERROR:
Channel 247
NotAvailable248ERROR:
Channel 248
NotAvailable249ERROR:
Channel 249
NotAvailable250ERROR:
Channel 250
NotAvailable251ERROR:
Channel 251
NotAvailable252ERROR:
Channel 252
NotAvailable253ERROR:
Channel 253
NotAvailable254ERROR:
Channel 254
NotAvailable255ERROR:
Channel 255
NotAvailable
Code:
   Revision: 23002001
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 160120 km
                    Date: 2067.01.31
                    Time: 12:48:46
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 160105 km
                    Date: 2067.01.26
                    Time: 06:21:58
Readiness: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Date: 2022.05.26
                    Time: 14:19:21
   Coding: 0228EE
   Coding: 1400B0
   Coding: 0400A0
   Coding: 000000
   Coding: 000000
   Coding: 000000
   Coding: B0FFFF
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 31
                    Reset counter: 2
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.13
                    Time: 06:17:06
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.16
                    Time: 14:19:28
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 0
                    Mileage: 160108 km
                    Time Indication: 0
                    Date: 2016.10.17
                    Time: 05:26:36
   Coding: 10800A
   Coding: 750B220300
1 Fault Found:
13654544 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 47
                    Reset counter: 218
                    Mileage: 160105 km
                    Date: 2022.05.23
                    Time: 06:17:04
   Revision: B9081001
   Coding: 042305
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 160105 km
                    Time Indication: 0
                    Date: 2016.10.13
                    Time: 06:17:11
   Serial number:
   Coding: 000000
Cannot be reached
   Coding: 030B1A73
Apologies - have missed this one - was on my holiday :whistle:
Perhaps BCM byte 0 is incorrect - the current coding suggests "central locking without SAFE function (deadlock) installed".
Reset coding to factory setting = "A0"
Hiya mate,
Thanks for getting back to me, We tried this yesterday but sadly it never worked. Any other ideas?
You need to test all lock microswitches as the safe lock will not work if there is an issue.
Still having trouble with this! Would there be a fuse for the deadlocks? Normal locking is operating fine just the deadlocks! Only other thing I can think of is the region of the van was changed to get the digital speedo active in the MFD could this cause my problem?
Shouldn't be related.
Does the alarm work?
I would try disconnecting starter battery for 10 minutes - to fully reset the BCM.
After battery disconnect you need to recalibrate windows comfort closing - one touch closing (affects also folding mirrors).
Take the window all the way down then hold the button down for a few seconds then take window all the way up then hold the button up for a few seconds. The same for the other window.
What's the actual status of door locks - please read/record them using VCDS?
An example of logged statuses here.
Can you make two sets of BCM blockmap data?
  • A set with ignition OFF (no key in ign lock), all doors closed & unlocked.
  • Another set with ignition OFF (no key in ign lock) all doors closed & locked from remote. Need to do fairly quickly because CANbus will shut down in about 60 seconds after locking the van (a wireless mouse would be handy to operate VCDS from outside of the van).
How-to blockmap:
VCDS > Applications > Controller channel map​
- tick/fill as below - click Go to make a set.​
The logfiles blockmap-09-... will be in folder C:\Ross-Tech\VCDS\Logs\....
How-to blockmap:
Thanks for this! Im next likely to get hooked up to VcDS on Tuesday or Wednesday so will get it done then in the mean time I’ll disconnect the starter battery! And do as you say with the windows.
The alarm definitely works have set it off plenty when testing to see if the deadlocks work neighbours love me!
