Deaky’s Kombi to Camper journey
Out of interest, how did you mount the consumer unit? just directly to the plastic bay separator or to something else?
The sides of the consumer unit are shaped, I made an angled shim and bolted the unit through it to the side and front plastics. This means it’s easy to remove to access the fuse box underneath.
any chance of a pic? considering another shameless copy :)
Having a tidy up in my bits cupboard today and cane across this wireless charger
Obviously my first thought was, can I fit this in the van. I took it apart to see what was inside.
Then removed the centre console from the van
Theres plenty of room underneath and even a couple of lugs I could use to secure it in place
The charger has two LED’s red for standby and blue for charging. I removed the led module, drilled a couple of small holes and mounted the module behind
A bit of tape to make sure everything was secure.
The charger has a micro USB connector, I’ve passed a USB lead through from the glove box and plugged it in.
Job done. Took about 30 mins
If I could have read this thread when I was 12 I would have paid more attention at school. Nice work as always @Deaky :thumbsup:
Made a start on the hookup today. Got the mini consumer unit and the EHU plug fitted under the bonnet. I've brought a Victron blue smart 3 output charger but upon inspection I can't control the outputs on the app like I thought I would be able to. My idea was to connect it to the starter and leisure battery and charge the starter as and when I needed to. Not all the time. I can't do this so I'm sending it back and getting a 4a charger for the starter and a 15a for the leisure battery. I'll just add another RCBO into the consumer unit.
the Victron Phoenix smart has 2 outputs,a dedicated 3a starter battery charger,1 charger 2 jobs,these are robust and brilliant units,although got a lower ip rating of ip43.
Today I’ve got round to fitting a Victron Smartshunt. Had to wait for a few bits to arrive. Namely some 10mm eyelets o_O I’ve bolted to unit to the side of the seat base
The smartshunt is able to monitor the voltage of the starter battery too, seeing as I already have a cable coming from the starter battery to under the seat it was a simple task to add a fused connection to this cable for the smartshunt to monitor. At the same time I’ve added a trickle charger to the starter battery.
The trickle charger is connected to the load output of the MPPT solar controller. In turn the solar controller is set to only turn on the load when the leisure battery is being charged. Basically, if it’s not very sunny or at night the starter battery will not be charged.
Here you can see the starer battery is 12.3v
On the solar controller, the leisure battery is receiving a charge, so the load output is automatically turned on
And new we can see that the starter battery is receiving a small trickle charge
Hi @Deaky, where did you get the headlining material? My roof is being done, hopefully in a few weeks and wanted to try and get that type of material on it.
Thanks,
This is what I used mate
WOW WOW WOW!!! So so so impressed.
Totally beyond my capabilities but yet so inspiring.
Couple of questions if I may Deaky. I have an edition Kombi and am wanting to use Calli sliding door card and tailgate cover and trim. Can you tell me where you obtained yours from and did you have to change B pillar trim to suit? Did the require any extra holes drilling in the frame to get clipped on?
I am also wanting to dummy the offside one but I have read they wont fit so will have to deal with that separately.
In the rear you used a couple of old door mouldings with speaker grills in to re cover and fit into ply panels. (what vehicle were these from as I really like the shape and would like to copy that idea).?
