IC needs to be changed if the centre LCD doesn't have sufficient resolution to display Direct TPMS details. But having said that minimum software version for IC and BCM need to be also established.@Robert
Does the cluster need changing?. I was under impression that said hardware allows for MFD to change.
Seems to be MY17 onwards then...The BCM (PQ25 Max4 7E0937090) needs to be minimum hardware version H81 to have address 65 (Tire Pressure) on CAN GW installation list.
But if yours is lower then not to worry cause BCM is very easy to be replaced and second hand units can be bought for approximately £53=€60
CorrectSeems to be MY17 onwards then...
Did you get a chance to upload your parameters to the direct tire pressure monitoring unit?I have 70% of this installed on my T5.1, just need to mount the module and get the sensors in the tyres. and yes it does work fine on PQ25 platform
