DIsable rear parking sensors using OBD11?
Howzat
T6 Legend
Just wondering if it's possible with OBD11 and if anyone can remenber where the setting might be?
Minor ding on the rear bumper has popped a sensor off so I've unplugged it until the bumper is fixed but I get this really loud and annoying beep in the cab every time I go into reverse. :mad:
Would turning volume off suffice?
Can be done in adapatations - separate settings for front and rear.
Not entirely sure but I think volumes do not affect the fault beep - at least I had some issues at some point and the fault is always at full blast.
Probably even removing the PDC module from gateway installation list would not stop it from working.
I may be wrong but I think unplugging the PDC module from under the dash would be the easiest fix
