Do Trendline's Have An Alarm?
Teesix
Simple question.
Not sure mine has one. Do the trendlines come with an alarm?
Afaik no they don’t, only highlines have a full alarm system
Thank you.
Damn. Thought all new cars/vans came with alarms but obviously not.
I opened the window, locked the car from the fob and leaned in to try and open the door from the inside to see if it would set off the (non-existent) alarm. You can't actually unlock it from the inside because it just stays locked. I'd have thought the inside handle would over-ride the lock mechanism.
Deadlock will prevent the door from opening from the inside, two presses of the key fob will disable deadlocks
Meta easy can.
I've put one on my last two vans.
