Door open alarm
RayB
Hi. Anyone know if there is a setting that will beep if you try to remote lock the van when a door is still open or ajar?
Kids left the side door half open and I didn’t realise when I I led the van and walked away - my fault for not checking but surprised the remote locking didn’t complain?
If one of the doors are not closed properly the van locks then immediately unlocks when you press the fob but it sounds like it’s locked itself. With Carista you can change the settings to bleep on lock, so if the door is slightly open you won’t get an audible beep, it’s a very reassuring change
I get a beep when the vans locked.
But a beep beep.beep... if a door or window is open.
"meta easy can" OEM alarm add on
I've done the same early on with my 6.1
Drying the carpet of your nearly new Caravelle out after it rained all night is a good reminder to not do it again.
The clue for me is to watch the indicators - if they don't flash it's not fully locked. I've occasionally not had the side doors latch fully close and this was the clue.
