Pete24
Hi all,
We have a 2015 T5.1 and a few months ago I fitted some LED bulbs to the DRLs and side lights - they must have been cheap crap as they have given me a couple of issues.
First off, one of the side light bulbs failed (as did the same bulbs in the rear number plate light!), so I have just re-fitted the original filament bulbs.
However, something a bit more serious has happened with the offside DRL. For some reason it has stopped working, and I know it is not the bulb at fault as the same bulb works fine when swapped to the other side, although I get the feeling the bulb has caused the fault! A standard bulb worked just fine for the first 5 years of its life, but within 100miles of fitting the LED bulb this happens. So something else is at fault. I was just wondering if anyone could shed any light on the issue before I spend money on an electrician to sort it out? Any common faults I can look at? Any hypotheses as to what might have happened?
TYIA
TYIA
