Hi all,
Van is a 2012 T5.1 180 DSG 4Motion.
I have recently started getting some kind of clunking noise under the van so today had it jacked up and was investigating possible sources. Been through every part of the suspension, drop links, ARBs, engine mounts, subframe mounts, blah blah and everything seems tight and no signs of movement. I am not that concerned and don't think anything is likely to drop out on the road in the near future.
When I was spinning the front wheels backwards and forwards I noticed I get a rattling noise out of the gearbox. I am assuming that the front diff in there is some sort of open plate design and it makes this noise with the engine off. Again, assuming, once there is some oil pressure in there when the engine is running everything tightens up and is as it should be. I got too cold and lost daylight so will continue tomorrow by jacking it up and checking again with the engine running.
However I wondered whether anyone could confirm anything about the design of the front diff on a DSG please. I have searched on here, and more widely, but can't really find a whole lot about it. Which probably means it doesn't go wrong very often, and this isn't something I need to be concerned about.
Thanks for any help or thoughts.
