I have had this issue for some time and it is now getting worse. 2016 2.0 T6 DSG (7speed). while driving the gearbox drops out of gear and the gear flashes on the MFD. flick to manual and back again and generally this cures the problem, but orange warning light on the dash for the next few starts until it clears. I have taken it to a gearbox specialist who has found no fault with the gearbox but the error seems to be coming from the instrument cluster. "vw transporter no faults in transmission only fault in the entire vehicle was instrument cluster u112100 data bus message missing"
And the following is from the diagnostic report (attached):
U010300 Passive/Sporadic Lost communication with gear shift module
P091400 Passive/Sporadic Gear shift position circuit
P173400 Passive/Sporadic Starter release from the selector lever sensor system
If anyone has some pointers that would be appreciated as this isn't something they repair. I have been advised to see an auto technician, but is it likely that i need to send the cluster away for a repair?
many thanks in advance!
Ady
Ady
