Sorry to crash this thread guys but I've got a similar query. I'm moving my rear air con control panel to the back of the van so it can sit in the furniture. From the front of the Van there is only two wires that come from the connector block under the seat so I've extended them and Tesa Taped the loom, job done! However, there's another 50,000 (slight exaggeration) cables with about 3-4 meters of length that go from the control panel to the HVAC unit. I could just wrap all that excess wire up and hide it in the cupboard but I'd much rather do a proper job by shortening the cables and re-crimping some new pins into the connector block. From what I've read above I need a Dupont crimp but I have no clue which pins or sizes I require (would rather not buy a load of different ones through trial and error). Attached are pics of the two different pins I need, any help gratefully received.
we going to need some more very close pics and some dimms.
as you can see from above there are many connectors that are very similar . .
