Wonder if you could help me out here?
As highlighted in my and others previous postings the Eberspacher heater thermostat has to be set at something like 7 degrees below the required van temperature as the heater draws the air from the footwell which is colder than the air in the habitation area. The heater keeps going until it detects that the air in the footwell has reached the required temperature Set at the thermostat.
As it was described to me a bit like a thermostat at home, you set it to 18 degrees but not every room in the house reaches 18 degrees ( that is how it was explained to me by my van conversion builder )
Although I have not tried this solution myself when I set the thermostat to 20 degrees at the weekend the van did became a bit warm when it reached 28 degrees.
The thing that irritates me is that: if I bought a £50K VW car and they told me the heater did not work perfectly I would ask them to fix it.
The company that sold me the van ( they were not the builders ) are trying to help resolve the problem.
Does the same problem occur in the VW California?
Does anyone know of a solution to this problem?
As usual thank you for your help.
