Ecoflow Solar
revdecal
I bought an Ecoflow glacier fridge which came with a 110w solar panel but even in direct sunlight it is showing zero input charge on my Delta Battery and not charging the fridge.
Has anyone else experienced the same issues?
I’ve tried 3 different cables now so unless it’s a faulty panel I’m a little lost
On that evidence it sounds like a dead panel.
Do you have a multimeter? If so measure the open circuit voltage across the panel in good sun. Should be around 22v
Yes, sounds like it. Ecoflow have requested it to be returned. Thats a good start
