Charging EcoFlow with solar
Right on the back of this, I've gone and spent my life savings (£8.12) on an XT60i lead to swap out for my XT60 lead currently in use.
With that and some app tweaks I should be able to nearly halve my charging time from the engine on method I'm using currently.
Then a bit of relay magic and I should have a fairly robust charging system!
Following on from my financial blow-out on an XT60i lead - I've wired it temporarily to my engine-running live and sure enough I am getting faster trickle-charging when the engine is running.
Closer to 13A as @roadtripper mentions above.
My next foray will be into a solar panel (100w ish I'm thinking) and then a break-before-make SPDT relay to swap from solar to vehicle when the engine is running.
If anyone has a suggestion for a suitable relay that meets the above criteria I'd be keen to know!
