Hi All,
on my T6 204ps my 2017, at 77k km I got engine light on and error P0401, insufficient EGR flow.
EGR cooler and pipes were half clogged by carbon residues and were replaced by a VW garage.
Reading in the forum, it seems this issue is exacerbated when oil consumption is high.
Oil consumption in my van was about 1L over 10k km when new, now it's increased to 1L over 6k km.
So I suspect the EGR clogging problem could come back again, even sooner than the next 77k...
I have some questions, if some expert could kindly answer:
1. can I exclude an oil leak from the turbo charger? From the scheme below it seems that the EGR system receives the exhaust gases directly from the exhaust manifold, not from the turbo downstream.
2. Can I assume that the burnt oil is getting into the EGR only from bad oil rings and/or faulty PCV valve?
3. How many hours does it take to check/replace the PCV valve?
4. what is the logical sequence of checks that I should carry out to find the root cause of oil consumption?
Thanks a lot in advance!
Cheers!
