MyfirstVW
Evening all, I’m currently battling the old adblue sudden drop to 650 no start alert (not over filled, VW say no software update needed) the usual lines of enquiry. I have a few fault codes via Carista but will be running a VCDS scan when my new laptop arrives tomorrow. So far I have;
15560 - EGR Sensor "A" Circuit Range/Performance
31103 - SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1
33262 - Reductant System Performance Bank 1
Upon mooching around with a bore scope I’ve found oily discharge from the front EGR pipe where it goes back into the inlet (this was changed about 3 years ago). And the EGR temp sensor 2 looks to me although hard to see like it has become corroded where it leaves the shaft of the sensor.
So 2 things I’m hoping you experts might be able to help with;
Does anyone have the part number for both a new EGR front pipe and the Temp sensor 2 (plugs directly into the forward most part of the EGR cooler just below the front pipe) in the workshop manual it’s identified as 21 (below). 2017 CXEB. Any help very much appreciated.
2nd, I’m really reluctant to start replacing costly Adblue parts in blind hope, is there any series of tests / checks I can do to try to pinpoint why I’m getting this error?
Thanks all, much appreciated.
