I’m trying to clear some corrosion faults I. The connectors under the passengers seat.
The conversion people had hidden the connectors, taped up,under the rubber mat but 4/5 pins have corroded and caused a bit of chaos.
I’m gradually getting there but does anyone know what t the connectors do?
Roughly the red has the nox and pms power feed, sorted that.
The greens have the rear lights on them,
My drivers tails lights are out.
There are 3- 4 pins that show signs of corrosion need cleaning or bypassing.
Curious to know what the thicker purple wires are
Also there is a black and cream connector?
Finally what’s the best fix? Cut the cable and ??? Solder , screw terminal block, etc etc.
Thanks ian
Thanks ian
